Will 2012 F225 power head fit on a 2005 leg/mid section
  • Will 2012 F225 power head fit on a 2005 leg/mid section
    Hi there,
    Im new to the site and wondering if any can let me know if a 2012 F225 power head will fit on a 2005 F 225 leg/mid section as my block has a bad corrosion problem.
    Thx Scott
    from a quick look,
    it seems like it will:
    the part the engine block attaches to -
    the "exhaust guide" - is the same from 2004 -2018 3.3L F225s
    (although the 2005 was made with 69J-41137-02-94,
    that now "supercedes" to 69J-41137-10-CA
    same as used on the 2012)
      To complicate matters, a 2012 F225 used a 6P2 block and 6P2 heads. A 2005 F225 used a 69J block and 69J heads.
      If a 2012 "dressed" power head (all components installed) is used it probably will work. If a 2012 undressed power head is used (with the intention of using the 2005 F225 components) it is going to be a problem.
      2005 F225 is a TXR or TUR model. 2012 F225 is an XA model. Mechanical throttle bodies on the former. Electronic throttle valve on the latter.
        Thank you Gentlemen.
        The power head I’m looking at is a F225XA which I think is a 3.3 litre. In theory the XA should bolt onto my 2005 3.3 litre midsection exhaust guide. I would install as dressed powerhead.
        Do you see any issues with this and do I need additional wire harness for the electronic throttle Valve?
        Thank you for help I appreciate it.
          I note that the lower cowlings are different. Could be something to do with the way that the control cables are attached.
