can someone tell me how the fuel enrichment system works thanks in advance
Yes, need to know the model.
Some models use choke plates, some use solenoids, some pulse the fuel injectors longer, some use an electro-thermal valve, ...
it gets fuel from the top carb bowl
it has two solenoids
dose the key switch activate it?
or dose the key switch activate something on cpu and it activates it?
the top fuel pump is the enrichment pump.
it draws fuel from the top carb.
the ECU controls the soliniods.
The enrichment system on the 90° 225HP engines (1990 - 1995) is con*****ed by a microprocessor. The choke switch and choke valve system have been eliminated. Temperature and throttle position are monitored and enrichment is automatic. An electromagnetic valve unit with a pair of injectors with different diameters are used to provide enrichment. Timing advance is also con*****ed by the microprocessor, thus eliminating the need to advance the throttle during startup.
Need to know more or is this enough?
ok thanks if there is something wrong with mine is the some were I can seed it to be fixed (they don't offer any new ones)
Originally posted by saw11mill View Postok thanks if there is something wrong with mine is the some were I can seed it to be fixed (they don't offer any new ones)
Address: 652 Harbor Rd, Wanchese, NC 27981
Phone: (252) 473-6267
Ask for the crusty ole guy in the back to do the work.Last edited by boscoe99; 06-21-2015, 07:51 PM.
ÂÂÂÂÂÂÂÂÂÂÂÂÂÂ
