F250 water leaking from both sides when running in a tub
  • F250 water leaking from both sides when running in a tub
    Anyone ever pay attention when your F250 is running in a tank. I attached some pictures of my engine running in a tank. Water runs out of both side covers on both engines. I don't remember it doing that before, concerned after the long harsh winter maybe a pump housing cracked. Both engines stored in down position.
    Anyone with a lift that can lower their boat down and start it and see if their's does it as well.
    Thanks any help.
    Nice tub.
    Can you leave the prop on?
      IDK, but I have to doubt its an issue. Stored down, shouldn't have been an issue.
      And both engines at the same time? Not Likely. Any alarms, overheats, etc?
      Someone will jump in shortly, but off hand, I doubt its an issue..
      Good luck..
        Nice tub.
        Yes you can.
