About 4 months ago I noticed that it was starting to bogg down on take off. I changed the LP pumps, plugs, fuel filters and the VST filter. Did not see the results that's I was expecting. About 2 months ago the motor started to cut out while running on plane and was still having the bogging down on take off. Tested the HP pump inside the VST tank and found that it was working intermittently. Replaced it and it is now not cutting out while on plane. But still has the bogging issue and running very rough. This past weekend while at the Skeeter owners tourney they had the Yamaha guys there working on motors at no cost (very cool I thought) but anyways I took it by their booth and they started looking it over and everything was checking out fine until they put a pressure gauge on the VST tank. It was pegging out his gauge. He said it should be at 35psi and it was getting over 100psi. I have a new pressure regulator on the way but is there anything else that you would check or do you think that this may be the problem. I do know that it is running very rich due to having an overload of fuel being dumped in the engine. But was just wanting to hear from anyone and what you think.
Thanks. Jonathan
Thanks. Jonathan
