Hi all,
Bought a used pontoon this spring which has a 2002 Yamaha T25TLRA 4 stroke. Ran great for multiple trips/ hours then one day on our way back in this alarm is going off and engine is running rough (rpm limiter im guessing / limp mode) I had zero clue at the time what the alarm was and we proceeded to run the engine for another 5 minutes at least as we made it to shore to beach it. Discovered it wasn't peeing. No blockage in telltale.
Fast forward a couple weeks I put in a new impeller and it now has a nice strong stream of water. Also did an oil change because she got HOT when it overheated. We lauched it in the water and putz through a No Wake zone which took 5 minutes or so. No alarms, telltale peeing great. Go to throttle up and soon as I get past 20% throttle it starts shaking and running rough, sort of like it's in limp mode. NO alarm.
We go to beach it. Check spark plugs, wiring, anything else that we could easily do. Started it up and revved it in neutral, it revs up just fine no issue. All of a sudden alarm goes off (constant tone) and limp mode / rpm limiter is back again. Turn it off. Pulled out thermostat and checked for any blockage. Ran motor without tstat. Over heat alarm within minutes. Water coming out of telltale not hot, just a little bit warmish. Engine doesn't really seem all that hot, certainly not as hot as when it overheated and wasn't peeing.
I'm not sure where to go next and don't have much knowledge of outboards. Don't know the history to it either. About ready to call a mechanic.
Any suggestions of something I could try before paying someone?
