Hi. I have a 2000 OX66 that will idle great with the engine cowling off but starts to loose rpms and stalls when I put the cover back on. Tech will not be available for 2 more weeks. I did all the usual, filters, lp fuel pumps, even chased down all the fuel lines. Any ideas. Also have a new o2 sensor.
Ox66
Hook up a portable tank directly to the engine and see if the issue goes away. If it does, work backward (old fuel lines, bulb, tank pickup, vent system, etc). If the problem persists, you know the issue is at the engine. Check fuel pressure.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by 99yam40 View Postmaybe exhaust gases leaking out under cowling and getting sucked into the intake
fixed exhaust and it ran like a champ.
Originally posted by brian3006 View Post
had this exact issue on a motor. only saw the exhaust leak by pure luck. started it early one morning and saw the puff of smoke due to condensation.. been spending all my time looking at air intake system
