Perhaps someone with more knowledge can help me out. I would like to add charging capabilities to my 2018 F8LMHB. I understand I need a rectifier. I have 2 empty green connections on the outboard already, assuming this means I already have the charging coil.
Do I just need to order the 6G1-81970-00-00 from Yamaha? Do I also need a regulator/what part number would that be?
As for the actual install it looks simple enough. But if someone could run me through it that might be helpful. I dunno if it will come with instructions or not, green connections should be pretty easy, ground to the block where other grounds are attached. Then run from there, along with the positive to my battery (positive to my Perko switch common with an inline fuse) It seems easy enough but strangely cannot find many Youtube videos specific to my F8. Just wanna be sure I can do this before I order the part.
