2006 F150 stalls, no power to key switch no warning lights and trim doesn't work. Checked fuses below and left of starter, all checked ok. After about 30 minutes, restarted normally, but I did notice volt meter dropped below 13 to a low of about 10 volts after it restarted. Volts dropped as rpm increased.2000rpm about 12 volts,4000 rpm about 10 volts. Is there any safety switches for low voltage that would cause this or any other safety switch that would reset automatically.
F 150 TXR kills while running@about 4200rpm
Originally posted by jakechamp View Post2006 F150 stalls, no power to key switch no warning lights and trim doesn't work. Checked fuses below and left of starter, all checked ok. After about 30 minutes, restarted normally, but I did notice volt meter dropped below 13 to a low of about 10 volts after it restarted. Volts dropped as rpm increased.2000rpm about 12 volts,4000 rpm about 10 volts. Is there any safety switches for low voltage that would cause this or any other safety switch that would reset automatically.
If voltage drops too far ECU, fuel pumps, etc will not run properly and will likely turn off
ÂÂ
