Yamaha F80 - carb synch - service
  • Yamaha F80 - carb synch - service
    Hi,
    I have some problem with yamaha F80 running on minimum. The engine is not running smooth on low rpm.. If it is on minimum (900 rpm) it's bouncing..
    The engine has 517 hours ...
    What you think is best way to solve the problem?
    I was thinking to dismount each carb and clean the noozle and change the fuel filter on each carb and then resynch the carb with home made carb synchronizer?
    Is there some manual how to do that?
    thank you..
    PEter
