Hi all
Recently bought a 2006 yam 2 stroke that turned out to be quite salted up.
I've removed the head and completely desalted, have a good flow from the exhaust jacket into the cylinder water jackets.
Only issue is that I dont have any water coming out of the exhaust in the mid section , I'm running in a test tank by the way.
Before I remove the powerhead to check over the base is this normal or should I expect a good flow from here?
Engine is running at normal temp now but concerned about water delivery from mid section.
