I have had trouble with cold starts on my vz200tlrc for a while. I recently got a tiny pinhole in the cylinder head allowing water to get in the #5 cylinder. I took both heads off to inspect and replace gaskets. With the heads off I noticed a pretty good amount of oil pooled in 1 of the ports of each cylinder. I’m not sure which port it is but it’s one of the bottom ones and it’s not the exhaust port. Is this normal? It seemed excessive. Some of the pools smelled like it was an oil/fuel mixture.
