I have a 60 hp that turns over but wont start. The engine was working fine when last used 3 weeks ago There is no spark at any of the plugs I have checked the fuse in the wiring harness and If I've done it correctly have incorrect readings at the pulser and charge coils.
My readings were
Pulser coil .02V to.05V with plug connected @ cranking speed
Charge coil 0 V with plug connected @cranking speed
Have checked the CDI and same thing not getting the correct readings
If any of these are playing up will they cause the other not to work?
Is there electrical power flow chart or description of how it works available?
I am also assuming I have the correct specifications. I'm using specs for a 60 from the net. I have not been able to find the model number for this engine, there are no tags where they are supposed to be.6H1-12 is all I've been able to match.
Any help will be appreciated
Gavin
My readings were
Gavin
