I have what I believe is ignition problems with my Yamaha 30DE (6J8) 1986, 3cylinder two stroke ,EU. It has been on land for some years, always worked ok and never had any major issues.
Symptoms:
I get resistance specs from CDI troubleshooting document, cannot find any info in service manual.
What else I’ve done:
Waiting for DVA adapter to measure peak voltages.
Any suggestions what is could be causing this? If temperature related it doesn’t feel like CDI issues as it shouldn’t change much in temperature.
Symptoms:
- Starts without any problems. Always.
- Can hear that engine misfires as it warms up. Ignition tester at spark plug shows decent spark.
- Pulser coils measures ok in resistance (each of the three wires to black gnd), warm or cold engine. About 360-370 ohms.
- Charge coil is a bit low in resistance when engine is cold, 230 ohms, measured between blue and brown cable. Warm engine it gives 280 ohms, within spec. (280-330 ohms).
- Checked with ignition light, it should be 2 degrees ATDC pick-up according to service manual but I had about 5degrees BTDC. If I adjust to ATDC, the engine more or less stops and will not rev up at all when warm (cold engine it revs up).
- With spark tester (light bulb) it is more or less nothing when engine is warm. Same for all cylinders.
- If I adjust to 10-20 degrees BTDC at idle, rev speed increases significantly and it runs much smoother at idle. But will not rev up.
- Cleaned carburettors and replaced gaskets, floater etc. Cleaned fuel tank. Replaced fuel hose between tank and engine.
- Replaced membrane and outer gasket in membrane pump.
- Changed all three ignition coils and spark plug caps. They were, all but one set, way outside resistance specs. New spark plugs (old ones black and wet).
- Checked compression, ok and very similar for all cylinders, warm and cold engine. I get about 9-10bars.
- Adjusted timing linkage according to manual with engine off. Have not verified TDC indicator position, but it hasn’t moved in the red paint.
- New battery.
- Checked ground connections, firmly attached and clean.
