Hello guys.
I have a 2000 Yamaha F50 outboard.
When i start the engine cold no problems appear, i will then sail getting the engine to mid range/high rpm without issues, sailing like it should be.
But when i put it out of gear back to neutral, the rpm will slowly increase by itself.
I can then turn of the engine, and the rpm at neutral is normal again, but when i put it in gear and back to neutral, the rpm will raise again..
Any suggestions on what could be wrong?
Could it be something with the Choke Solenoid?
Picture of how my carb linkage looks like attached.
