Motor kicks up in reverse
  • Motor kicks up in reverse
    My 225 ox 66 rises up when I throttle up in reverse. Is it an adjustment or a bad part?
    Sounds like a free piston oring failure.
      it also depends on how hard your throttling up.
        Just giving enough throttle to back up or stop. It's a twin engine boat and the other motor doesn't kick up.
          possibly the shock absorber valve has failed or debris in it.
          no adjustments on that unit.
            Thank you! Is that valve accessible without disassembling?
              Nope, it is not
