Motor has been doing good for a while now. I thought I had bad water leaks until I learned all was normal. I still have a lot to learn from this project motor.
Like I said it’s been running good and I’ve been enjoying trips to the lake. I was flushing the motor at idle here at home and after warm up all of a sudden the rpms drop. I checked temperature right away and it was 138. Then I grabbed the primer bulb but it was rock hard. After about a minute the rpms came back up to normal. I ran it again the next idling and after a while the rpms went down again and this time it died. Started back up with one pull but I stopped running it and started checking things. Here’s what I’ve done.
Checked compression 105 , 110 , 105 . Checked plugs and they looked good and all the same. Next I ran the motor and pulled the plug wires one at the time. All three changed the idle the same. I started at the portable fuel tank removed fuel , checked for water and trash found none. Tank is clean so is pick up. I’ve made sure all connections and clamps where good while inspecting the fuel line. Did not pull the fuel water separator because it only has about 10 hours on it (let me know if I should anyway). Fuel filter under the cowling was clean again no water.
Tomorrow I’m doing a spark test for color and length of spark. If that checks out I figure I’ll pull the carburetors.
Question: If a needle is sticking closed now and then would it cause rpms to drop or would it start missing?
This outboard has turned out to be a whole new animal for me. It’s my first and I’ve been enjoying learning while working on it thanks to everyone that’s helped me along.
I really appreciate any advice or ideas what to check on next. Thanks
