Hi folks. New to the forum. I've recently bought a 75hp yamaha 2 stroke. I've done all the obvious things to try rectify my problem. It starts fine, it revs pretty high at first then once the revs settle, it'll splutter and then cut out. It'll start straight back up again however, but then do it again. If I manage to engage it into gear before it cuts out, it just bogs and dies. It's an intermittent problem as I have been out in the boat and it sometimes runs fine under load. But when coming alongside the pontoon it will cut out when I engage neutral to go astern. It will only rev up to 4500 when full throttle in gear, but will rev to 5500 in neutral. Is this normal? Or should it run higher than 4500 when full throttle? Tia
2001 75hp yam 2stroke misfiring and bogging
Originally posted by Tomtom121212 View Post. but will rev to 5500 in neutral. Is this normal?
Please for your motors sake, don't do this...
4500 for WOT under load is on the low end of "normal" might need a lower pitch prop...
what rpm is the motor idling at? both in neutral and in gear?
might be time to take the carbs apart for a good cleaning..
Originally posted by Tomtom121212 View PostThe spark is intermittent on the middle cylinder. This has been checked. Compression is good. What rpm should it be maxing out at under load? Could you tell me? Thanks
