I'm back...with more problems. I now have 2 stroke oil draining out the exhaust / prop. The tank level has definitely gone down and I haven't ran it since my first post here. This is what was happening all along I'm sure...but how?
The check valves are all good - the carbs are off and I can see the ports where the oil is injected into the intake, it's completely dry so it's not coming from the oil injection ports.
There is an O ring that is behind the oil pump, I'm guessing that is to keep oil from leaking around the oil pump? Is it there for any other purpose, like leaking into the engine where the oil pump is connected to whatever spindle makes the pump spin? Just taking shots in the dark at this point.
