At startup the motor smokes really bad and smokes for about 2-5 minutes. Once it clears up it's fine and doesn't smoke much at all. I replaced the check valves in the oil supply lines as one was stuck open. I've tried to adjust the oil linkage rod (I have the Mikuni oil pump). I'm guessing with the throttle plates wide open I need to adjust the linkage so it's just about at the stopper (for wide open) There is no stopper for idle/closed. All 3 carbs have been taken apart, adjusted and cleaned.
What else could I be missing here, I don't understand how excessive oil is getting to the cylinders after sitting for a while.
Mods please remove the image below if it goes against forum policies.
