I have 19bay with 115 yamaha4 what is cruising rpms how long can run at say 5000 thanks swanboater
rpms
Originally posted by swanboater View PostI have 19bay with 115 yamaha4 what is cruising rpms how long can run at say 5000 thanks swanboater
what is a 19bay
what is the model # stamped into the tag on bracket of the motor?
What prop are you running and what is the WOT RPM you get with boat loaded as you would normally run it with that prop you have?
If rigged and propped properly you can run it till it runs out of fuel at 5K
