yamaha F40 four stroke carbs
  • yamaha F40 four stroke carbs
    my carburetor needs to be cleaned. I miss a drawing of them. someone who can help with that. thanks in advance
    What model F40?
      Its from 1999
        If this is a model F40TLRX, would it be easier just to post that
          Correct F40TRLX.
            Here is the drawing
            1999 F40TLRX Yamaha Outboard CARBURETOR Diagram and Parts
            A better copy of the drawing is available at www.yamahaboutboards.com
            Go to the parts catalog there and look up your motor. Open the illustration for the carburetors. For instance.
              Thanks. This will be helpful
                By the way, the F40 carburetors are some of the most complex and difficult to clean. Carbs need to be fully disassembled and cleaned in a heated ultrasonic cleaner using a good cleaning solution.
                Blow all passageways and maybe use a piece of soft copper wire to rod out any orifices. Count the number of turns for the idle mixture jet before you remove it from the carburetor.
                A vacuumate will help to synchronize the carburetors after they are reinstalled.
                  Thanks boscoe
                    1999 F40TLRX. Took my carbs apart and cleaned and did not count the turns for the pilot jets. Any way to know where they should be set? It seems to be running fine on the muffs with the jets bottomed out???
