I recently noticed on my new boat equipped with CLP that I cannot do a partial tank fill and get an accurate fuel level reading. I ended up filling the tank and doing a re-set. I read on the THT that Yamaha is supposedly working on a fix for this issue. Any word on this on this end? Thanks.
CLP fuel level question
It is presumed that you are talking about the "fuel aval" amount. No fix that I have heard of.
Original Command Link speedometer was like this and it was carried over into the Command Link Plus instrument.
Folks complained about it and Yamaha made a change that ties the fuel aval quantity to the fuel tank sender(s). A step backwards IMO.
There is a four step calibration procedure that you can perform (requires the tank to be empty to start with) and you can install a better fuel quantity sender from CENTROID PRODUCTS - Computerized Tank Display - Electronic Senders - capacitive fuel gauges to make it a bit better.
