Yes, lift pump has a mechanical plunger that I assume is driven off a camshaft lobe.
2011 - F70LA, 4 stroke low speed fuel issue.
Originally posted by jtmac2011 View PostUpdate, no luck with the 2 suggested fixes. Same issue persists. But the fuel cooler provided another thought for possible repair, could the water pump not provide enough water at low speed? There is definitely a connection with heat...I.E. after start up the fuel problem does not occur until after engine is fully warm, then the 10 minute run time intervals begin.
I very much doubt it wil be a water pump issue as the engine requires more heat dissipation at higher speeds than lower speeds & also the overheat alarm would sound, can you confirm that the alarm is operational, to do so, remove the red lanyard from the emergency stop switch & crank engine with it removed & the alarm buzzer should then sound with the clip removed whilst cranking !!
Originally posted by jtmac2011 View PostYes, filter housing was replaced. Engine was run until problem started. The hsg was then changed, problem still present.
And, yes alarm works.
Question: How is the VST vented?
another suggestion could be the low pressure inline fuel strainer p/n 6C5-24251-00, this is mounted between the low pressure lift pump & the VST assy, there is also another fuel filter inside the VST p/n of
6C5-13915-00, is connects directly onto the high pressure fuel pump, these are long shots but maybe worth trying !!
Originally posted by Tony Harper View Post
via the p/n 6C5-86120-00 "solenoid valve assy" which is con*****ed by the ECU thru the main engine wiring harness.
So, ISC and water pump replaced, same problem. During my test run, I immediately disconnected the vent tube from the solenoid valve assembly as soon as the problem started. Reprimed the VST and ran for another 30 minutes @1000 rpm in gear and cowling removed, no issues found, motor ran perfectly. So, thinking I found the solution I reconnected the VST vent tube and ran an additional 30 minutes, again with cowling removed, but problem didn't return. So now I am confused. My thoughts are the cowling was removed when vent tube was reconnected, so additional heat from under the cowling could be aggravating this problem. Next run I suggested to the Tech that we try one of 2 things: plug the vst vent tube to mimic a faulty solenoid valve; or, install a temporary 'tee' in the vst vent tube and pull it through the cowling so that we have access to its end (this will allow for a quicker disconnect of the tube without removing the cowling).
Finally made progress, the problem was the solenoid valve...I.E. valve was not functioning properly, as a result venting of VST was limited, this caused a back pressure in the VST that resulted in no fuel flow from the low pressure fuel pump.
Fix: The sensors that provide input to the solenoid, by way of the PCU, were out of adjustment and had to be reset using an Analyzer. Ran the engine under all operating conditions since that repair and all is good.
