Yahama c90hp 2000 model
  • Yahama c90hp 2000 model
    Can somebody please tell me where the thermostat is located on a 2000 90hp 2 stroke I am sure its in front of my face but I cant find it
    Top rear of the motor. Right in front of your face. Item 42 in this illustration
    2000 C90TLRY Yamaha Outboard CYLINDER CRANKCASE Diagram and Parts
      That pressure control valve plunger/grommet is under that 4 bolt cover also....good idea to check/clean/replace these also while the cover is off checking the thermostat....you may want a new gasket for that cover also....
