I have a set of 200 HP 4 stroke Yamaha's, F200XB & LF200XB (2014's)
My problem is with the LF200XB. Why trying to warm up the engines for their second oil change, the LF engine did not pass water thru the "pee hole". These engines have only 89 hrs total time & this could be a warranty item, but I am 150 miles from a dealer. Is there anything simple to do to get water flowing thru the engine? The engines were thoroughly flushed (15 minutes) prior to winter storage. Ooops, edit, The engines were drained, blow out with 10 psi air & the upper flush hose connections were left open.
