Hello,
I recently purchased a Yamaha 70B outboard motor 2005 and following winter, I took it out of storage and planned on servicing it. It started with no issues following new spark plugs, fuel filter and fuel.
However, I’m getting an add oil blinking light on the tach, however the oil tank is 90% full, there also appears to be air or gaps in one of the oil lines (big thick one) as pictured below. I tracked the big pipe which goes into the top on the oil pump. It’s the thick pipe running over the top of the oil tank on the engine and down in behind the oil tank to the top of the oil pump?
Any advice would be much appreciated, I’m about 200 miles from my nearest outboard dealer.
