Long shot here...but I am at the end of the road with troubleshooting my issue, so here it is. 2010 VF200LA is runs fine while moving but if I sit at idle too long I get the overheat alarm. The tale tell pees hard while up but will dribble and eventually cut off and or steam if at idle too long. I have done the thermostats, the impeller, and flushed the system with rydlyme and still the issue returns. When I pulled the thermostats I looked inside and it seems clean to me. Open to any ideas on what to do next. Also worth mentioning that when I hook the hose up to flush the motor the tale tell will sometime pee and other times will either dribble or nothing at all. Thanks!
Vf200LA Idle Overheat Alarm
Kit Includes:
1 Cartridge Insert 61A-44322-02-00
1 O-Ring 93210-86M38-00
1 O-Ring 93210-37M67-00
1 Impeller 6E5-44352-01-00
1 Woodruff Key 90280-04002-00
1 Cartridge Outer Plate 6CB-44323-00-00
1 Water Pump Gasket 6CB-44315-00-00
2 Dowel Pins 93606-12019-00
4 Bolts, With Washer 90119-08M14-00
