Yamaha F115 Tachometer issue
  • Yamaha F115 Tachometer issue
    2002 F115 Analog tach became erratic last season, this year goes to top scale when switched on. How can I check tach function before purchasing a new one? And are these analog tachs still available?
    Thank you
    If the needle goes to the top of the scale with just the key on, and remains there, the tachometer is kaput. Presumption being that the needle stays there when the motor is running.
    Analog tachometers are still available. From Yamaha and others. See Yams at www.yamahaoutboards.com
      Yes, it stays at 7000 when running, whenever switch is on. Thanks.
