I have a 2017 F25 WLC with close to 500 hours that is running at about 3200 rpm at WOT and stalls when I back down the throttle into neutral. I do standard service religiously and it has brand new fuel filter, spark plugs, etc. It appears the fuel pump is working properly as the bulb is always full and has a reasonable about of pressure when running. I gave it an extra squeeze while backing down to see if that would prevent a stall but no joy. Before I go diving into the injector pump, is there a more simple cause I could be missing? The motor is mounted to my home built floating tiki bar (not a trailerable model) so I would have to remove it to take it to a dealer.
Thanks!
Thanks!
