i have a yamaha 2000 model 100 hp outboard motor and lost one of my carburetors
  • i have a yamaha 2000 model 100 hp outboard motor and lost one of my carburetors
    I have a 2000 model 100 hp outboard Yamaha four stroke carbureted model. I lost one of them the second to last one down,one with the choke on it. I found four stroke 80 hp carburetors they seem identical was wondering if they can work on my 100 hp with out doing anything. Can they work?
    If they are the exact same part # they should work.
    But I do not think 20 more HP could be generated from the same fuel and air that 80 let into the motor
      my 100 hp carburetor # are 67f and the 80 hp carburetor # are 67g
        No !!
        With Yammys I have had no luck finding jet sizes,air bleeds, venture size and the like ....DO NOT RUN that carb !! till you find those..But,,I havnt looked much at all in years
          there seems to be three threads on this???? Assuming you are rebuilding this engine (you didn't loose the carby whilst driving,or stolen) then dismantle one of the original carby's and compare, as advised jet etc. for jet etc. , check bore diameter too.
            my internet was acting up I accidently post the same thread twice.
              anyways I had an mechanic working on my 100 hp motor and he lost one of the carburetors for it. I found 80 hp carbs and was trying to find out if they would work on my 100 hp.
                Typical
                That's Typical!
                  Hi!
                  I have a carbed F100 that already was a F80 and carbs are diferent!
                  At 1st sight they looks like the same (same size, same venturi, etc) but on the F100 carbs if you remove the top plate you'll see a few holes that the F80 carbs donīt have (allowing more air get into de carb is my guess)
                  I had pics of this... I will try to find them to post here.
                  If your mechanic "lost?" you a carb he must find a carb for you (IMO)
                  Have a spare set but not for sale
                    K thanks that's kinda what I wanted to know, good info to have. I was trying to avoid having to order a carb for my motor thinking the 80 hp would work but sounds like it won't. So thank's for the info i'll look around for a complete carburetor to order.
