I have a 2010 T50TLR. I began to get an overheat alarm in idle. I have had it into 2 mechanics. One is Yamaha certified. Both flushed and replaced fuel pump, thermostat and impeller. The Yamaha certified mechanic along with the Yamaha help line have said they can't figure out the issue. With little to loose I downloaded the repair manual and got started. I have been told this model does not have a poppet valve. Can anyone explain how to find the IAC valve? Or post a pic? I found it in the manual and it shows 2 screws holding it in place but the actual location is not clear. Any other possible solutions would be appreciated as well.
