Just want to know if spraying down the power head of a F40LA outboard with Yamashield is worth doing if used in fresh water. My motor and boat are stored in my home garage. I only use this motor in fresh water and used this spray once a year since buying the motor new two years ago. I spray it below the belts and air intakes. Do you guys use this in freshwater?? Thanks.
Do you guys use Yamashield Spray??
Given how you use/store the boat, it's not really a necessity. However, it's not like using it is going to be "bad", you know? The only thing that can happen is that you help to thwart corrosion - even though it probably isn't needed, I can't see how using it would be do anything but possibly help. I use Boeshield, but am in salt - I assume Boeshield is similar.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
I use LPS 2 however my water can be brackish or salt(depends on how much fresh water is dumped from Lake Okeechobee, Fl) .
The powerhead looks brand new (2006 model), so IMO, worth the $ to keep corrosion down, especially with all the electrical under the cowl..
.Scott
Originally posted by byron.akhavi@gmail.com View PostDennis....thanks for the response. I think that Boeshield is a Boeing product and it's ideal for salt water use. I think the Yamasheild is something Yamaha tried to replicate and called it that name.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
