So the T & T is NOW working?
If not did you try to bleed / fill the T&T by doing the following;
The engine needs to be trimmed FULLY UP and set on the mechanical support arms. All the rams extended... Then pull the fluid check plug and top off..
You may have to do this several times.
This procedure should be in your owners manual as well..
If the unit is leaking externally, you'll see fluid.
