2003 50tlrb
    https://youtube.com/shorts/vxInsGdZlNo?feature=share
      I looked at a manual also and you are correct on the marks.
      but I would be a good idea to use a timing light also to verify the correct timing
      if you have good compression, spark and timing, and it is advancing as it should,
      then you are left with a fuel problem with one or more cylinders
        So I did the linkage procedures (WOT screw, throttle linkage to get all the carbs to open and close at the same time, etc etc
        Is there anything that needs to be done with the flywheel? I’m confused on it’s purpose. Not sure if setting it to TDC actually does anything when resetting the carb/idle/WOT adjustments.
        I took the cover off and saw top dead center along with increments of degrees like -25 -20 -15 etc
        Can take a pic tomorrow
        • #19
          Also I agree with the fuel thing. How can I figure out if all cylinders are working and taking fuel?
          did a compression test and they were alll at the same reading. (Forgot what the number was)
          • #20
            This is my issue
            https://youtube.com/shorts/FYqdylnplNg?feature=share
