Hi, I am new to this forum and was wondering if someone can help. My f40 2011 buzzer alarm sounds as soon as you start the motor and continues to beep in neutral but as soon as you place the motor in gear the buzzer stops. It is not the buzzer sensor itself because I replaced it, also changed the oil in the engine and replaced the thermostat. Can't seem to figure this out any suggestions would be appreciated, thanks for your time Wyattchesley !
And after you have emptied water from your fuel filter, and found why the water got in there in the first place, then take the time to read your owner's manual. The complete manual. All of it. In the time it took for you to have needlessly replaced the warning horn, the buzzer and the thermostat, you would have gotten to page 31. At least.
See page 31 regarding the specific problem you are currently having.
http://yamahaoutboards.com/sites/def...8626-10-18.pdf
Cleaned the fuel filter cup and also replaced the filter in the water separator in my fuel line and the alarm still sounds like before. Anybody have any other suggestions or have had this problem.
Can you tell me exactly where the sensor switch is as I am no outboard mechanic, thanks again for your time !
thanks, I unplugged the sensor from the cup and the alarm stops so I'm going to purchase a new one to see what happens.
Originally posted by TwinTurbos???, do engines filled with water run?
Focus. Focus.
You might want to start your own post about engines filled with water running. Hopefully, someone can give you the answer you are seeking.
Originally posted by TwinTurbosThere is nothing false positive about a fuel system overrun with water, you might well get a buzzer, but there will be no ignition, that is the result of water in an internal combustion engine. A bright kindergarten graduate would know this. You might be fooling some of the people here, that you can diagnose every engine fault without ever seeing the engine, but you can not, no one can, not even the people who built the engine can do that, and that goes for any engine, from any manufacturer, whether the engine be in a toy airplane or in the biggest container ship afloat.
You may want to read the above posts again.
The buzzer STILL went off even after emptied/cleaned.
From the OP;
"thanks, I unplugged the sensor from the cup and the alarm stops so I'm going to purchase a new one to see what happens".
As directed, he disconnected the switch, the buzzer stopped. By reason of deduction, the buzzer is bad... Doesn't take a brain surgeon to figure that out.
May I ask what your experiance is mechanically? (not being a smart a$$)Scott
its not the first water detect switch in that cup that ever failed.
why Yamaha engineers mapped the ECU to only sound a water detect in N is beyond me.
try to get it warrenteed, Yamaha did have some issues with certain switch's.
The guy (seastars/twin turbos) has a serious reading and comprehension disorder.
OP was first informed to check the fuel filter cup for the presence of water. OP did this and reported that there was no water in the cup. No water in the cup means likely no water to the engine.
Customer was informed to read the owner's manual as the owner's manual addresses an intermittent warning tone if and when the motor is in neutral.
After the OP confirmed there was no water in the filter cup he was then informed to disconnect the sensor on the basis that the sensor has failed. This is a known issue with certain Yamaha filter cups. OP did this and the warning tone in neutral ceased.
seastars could not follow the threads.
ÂÂÂÂÂÂÂÂÂÂ
