My 1998 Yamaha 25ELRW outboard runs rough at RPM below 2200. Above that it runs smooth and has plenty of pep, gets right up on plane. It starts right up but idles rough and shakes until the RPM rises above 2200. The carburetors have been cleaned and the fuel pump was rebuilt. The compression is 90 lbs in both cylinders. Adjusting pilot screws doesn't seem to make any difference. Any ideas?
rough running at low rpm
I would think that motor should have more compression than that, but it could be the gauge used.
either the carbs pilot jets and passages are not really cleaned properly or maybe the fuel pump is leaking some fuel into the crankcase would be my guess
but then a small vacuum leak or reeds might cause a low RPM problem.
did you check to make sure idle timing was in sec and advancing as it should?
Checked flywheel markings for static timing, they lined up as manual shows. Timing light indicated advance when engine running. Also I assume timing is advancing as motor quickly runs with power and runs up to 5,000 RPM when throttle is applied. I couldn't figure out how to read timing marks with timing light.
Originally posted by fisherman363 View PostChecked flywheel markings for static timing, they lined up as manual shows. Timing light indicated advance when engine running. Also I assume timing is advancing as motor quickly runs with power and runs up to 5,000 RPM when throttle is applied. I couldn't figure out how to read timing marks with timing light.
Originally posted by fisherman363 View PostI'm familiar with compression testing and I believe the reading is correct. tested with engine warm and throttle wide open.
have you used more than one gauge to see if they agree?
Finally got back to trying to solve this problem. The static timing as shown in the shop manual is adjusted as indicated in the book. Also the manual calls for 7 degrees ATDC at idle but my timing light reading shows that it's actually running at 2 degrees BTDC. So I need to retard the spark but there is no adjustment left to make. If I adjust the magneto linkage to its longest length it still doesn't retard the spark enough to get the proper timing light reading of 7 degrees ATDC? Is there another adjustment to retard timing that I'm missing?
It has been a long time since I played with the timing on my C40, but I think at start up the timing was advance some and then when motor reached a warmed up state (temp switch activated) it would drop back .
how long did you run the motor before checking with light?
does you motor have two temp switches like my C40?
if it does is it functioning properly?
I had to change my CDI to correct the 14 ATDC it was doing instead of 7.
With yours advanced the RPM should be too high,Last edited by 99yam40; 06-11-2021, 12:56 PM.
