225TLRS tilt/trim elect operation
    Tks for the update and congrates!
      Originally posted by mygrady1 View Post
      OK. Here's what I found. It seems that my gas line was pushing down on the wires of the t/t switch and had chaffed the wires. After lifting the fuel line and separating the t/t wires, both helm and motor controls operate fine. Go figure.
      A 70 year old got lucky, but only in this.
      Not a mystery really, if you want to go to the trouble to map out the circuitry.
      Because it has two switches it was designed that both can't operate simultaneously to avoid positives connecting to negatives (spark, burn.. kaput).
      And I am assuming you have ruled out breaks within wire! That you haven't moved the wires that they are now touching internally.
      Just remember things can seem strange with wiring when shorts, or open circuits occur, and they can be intermittent.
        Just moving things around does not fix the problem in the long run.
        If open to moisture the wire will corrode and cause more problems .
        you need to repair the wiring
        • #19
          2 coats of liquid tape and moved the wires so that nothing was rubbing them.
          • #20
            Then hopefully you are good for a while
