I'm replacing my current 1995 yamaha 150 2 stroke tach and speed gauges. I bought new gauges and the harnesses on the tach aren't the same.I have only 1ea 4 wire connector coming off the new tach and the old one has 1ea 4wire connector and another 2wire connector w/ 1ea green/white & 1ea. green/red.I can connect the 4 wire with all matching colors but there is nowhere to connect the 2ea green wires.Thanks for all the help I just bought this boat and want to get out in it but these old gauges are unreadable so need to get the new ones working!
1995 yamaha tach and speed wiring help
You seem to have a tachometer that was made for 2005 and later Yam motors. Not recommended for use with pre 2000 model Yams because the trim scale will not be functionable.
You really need another tachometer that has two four pin connectors plus some individual wires.
Here are some diagrams for your consideration.
red/green is low engine oil visual.grn/blk is oil level ok or remote tank level visual.
if the new tach has dip switchs its compatible for the visual indicates. you will need to correctly set the tach switchs for 2 stroke,12 pole alt .
Thanks for all the help guys!!!! This forum is an incredible help. I ordered a wire harness adapt. from amazon that takes the two connections from the motor and uses jumpers, I guess, to convert to a single 4 wire connection.
ÂÂÂÂ
