Yamaha 6Y5T Speed and Tach Gauges Wiring Questions
  • Yamaha 6Y5T Speed and Tach Gauges Wiring Questions
    I am looking for wiring assistance connecting a Yamaha F200 to gauges 6Y5T-DO 93C and 6Y50-AO 864. What wires do I connect the wires from the Fuel Tank Sending Unit? Also, the Top Bar on the Trim Level Gauge is flashing and not reporting the proper level. Thanks in advance for the help! Toby
    the white Speedometer wire is for the fuel tank sending unit
    the other wire of the fuel sender needs to be connected to ground;
    that can be done using either of the two black wires speedometer wires
    (the other gets connected to the black wire of the harness from the keyswitch)
    as for the trim,
    there have been some differences in "F200" over the years
    exactly what year/model is the engine?
      The engine is a 2015 year F200XB. Thanks again Fairdeal!
