I was reinstalling the tilt/trim unit yesterday
on the 2005 F225 -
there are 8 M10 bolts that hold it to the brackets.
They are doubtless original to the engine.
I had previously chased the threaded holes with a tap
to make sure they were in good condition,
and wirebrushed the bolts,
and then applied teflon pipe sealant to the bolts before insertion.
As I was snugging the bolts -
not final torque, but starting to tighten -
the head of a bolt popped off !
and then another.
Classic example of 'crevice corrosion' -
the outside of the bolts looked fine,
nothing to suspect that they were compromised.
I'm just lucky that it happened at installation,
not when removing them after a long period
when they might be reluctant to be backed out
on the 2005 F225 -
and then another.
