after replacing the impeller in my 2008 50tlr 2-stroke, the motor starts in the forward gear and stays in forward. there is no neutral or reverse to be found. I removed the lower unit intending to rotate the shift shaft to neutral but I can't locate neutral or reverse after rotating the shift shaft through it's complete range or at least it feels like the complete range. my intention was to put it in neutral and put the shift lever in neutral and then re-attach the lower unit. the engine shifted perfectly prior to the impeller replacement and has extremely low hours on it so I can't imagine there is something mechanically wrong with the lower unit.
I followed the procedure in the Yamaha repair manual which offered no cautions like place the shift lever in neutral before removing the lower unit. I am out of ideas and would greatly appreciate any help or ideas that anybody can offer. thanks in advance
