2002 130BETO Oil Wiring harness - Diode failure
  • 2002 130BETO Oil Wiring harness - Diode failure
    Hi All,
    My yam fails to top up the 2t oil from the main tank to the smaller tank in the engine. will do so when you manually flick the switch in the engine...
    We have swapped out all the parts from my friends boat to mine and still wouldn't work.... Until we swapped out the wiring loom element of the 2t system.
    HAPPY DAYS - until I went to order a new one... £160 + VAT + Delivery & a two week lead time from Japan. (im UK based) - couldnt get one online anywhere!!
    Is there a way to replace the diode that's failed within the loom itself... when I strip it out properly ill take a good look and see for myself - If not ill order a new loom - its just a bit expensive for a new diode essentially.
    Has anyone done it and is it an easy / worthwhile job?
    Thanks for the help - greatly appreciated
    Dan
