Manual should give a minimum peak voltage spec, so measuring with a regular meter will not give you something to compare to spec.
but the charge coil gives the voltage to all 3 ,so if 2 are firing then the 3rd should also
"doesn't want to rev up even with the prime start lever at the control but if you open the carbs buy pushing the linkage that connects the carbs it will rev up and i can see all 3 spraying fuel mix.
what does prime start lever at control mean?
fast idle lever maybe?
if you are not having the motor in gear on the water while opening the carbs then there is no load on the motor so reving up means nothing at all.
it does not even need all cylinders firing to rev in neutral
does the timing linkage and lever under the flywheel move when you put the motor in gear and advance the throttle?
what about when you move the carb linkage by hand as you were talking about?
