06 25hp short to long shaft
  • 06 25hp short to long shaft
    Can you swap the lower unit on an 06 25hp 4stroke short shaft with a long shaft by just changing the lower unit?
    the shaft will not be the same length, so it will not work.
    going longer without a additional section added to the upper casing so it can be bolted up
