Tough crowd, just trying to figure out what motor this lower unit is from (per thread title) Since it has a standard prop shaft I figured that a standard Yamaha prop will fit it but, since the water pump kit that fit is from a Dx model motor I wasn't sure if I some hybrid of lower unit.
Identifying lower unit
You are over thinking this. There are no hybrid lower units.
I gave you information as to how to inspect your lower unit to determine what model type it was originally used on. I think the answer, should you choose to do the inspection, will disclose that it is a conventional gear case. That is, if it uses on only one propeller.
Better still, why not take the motor to a Yamaha dealer and ask him to install the correct propeller for you?
Originally posted by Flying fish View PostTough crowd, just trying to figure out what motor this lower unit is from (per thread title) Since it has a standard prop shaft I figured that a standard Yamaha prop will fit it but, since the water pump kit that fit is from a Dx model motor I wasn't sure if I some hybrid of lower unit.
Are the cases the same with different guts so someone could slap in standard guts?
Never mind the cases are a totally different
And why would the water pump be different on a DX from a standard?
But it is looking at the part #sLast edited by 99yam40; 05-06-2015, 01:46 PM.
Originally posted by Flying fish View PostYes , this was fun finding the right water pump the first time I changed it.
Â
