F150TLRC faint squeak at idle.
  • F150TLRC faint squeak at idle.
    F150 4str. sometimes at low rpm in gear, or at idle, there is a faint higher pitched squeak. Hard to tell exactly where it's comin' from. Only occurs in the water, not on the trailer with muffs.
    most common squeak on those is the driveshaft bushing needing to be greased
      Plus 1 ^^^^.
      You MUST use the Yamaha waterproof grease or similar. Regular grease won't last a month and start squeaking.
      My '06 F150, when dry, would squeak about 1700 RPMs and sound like birds chirping in the distance..
          Ok, thanks guys, will do that.
