F150 4str. sometimes at low rpm in gear, or at idle, there is a faint higher pitched squeak. Hard to tell exactly where it's comin' from. Only occurs in the water, not on the trailer with muffs.
F150TLRC faint squeak at idle.
Originally posted by 99yam40 View Postmost common squeak on those is the driveshaft bushing needing to be greased
You MUST use the Yamaha waterproof grease or similar. Regular grease won't last a month and start squeaking.
My '06 F150, when dry, would squeak about 1700 RPMs and sound like birds chirping in the distance..
.Scott
