Originally posted by boscoe99
View Post
Electric Oil Pump Test Proceedure
Originally posted by boscoe99 View PostFirst, check the yellow wire for voltage. I don't think there will be any.
Then, set the meter on the continuity scale with one probe to the engine block and one probe to the yellow wire. Turn the key on and see if the yellow wire is one and the same as the block ground.
Yellow is normally key on power. In this case I don't think that it is.
ok, so now we know the control side of the relay is working.
any r/y wire will have 12V to engine ground at key on.
the ECU then completes the relay control ground path via the yellow wire.
the black wire is for the fuel pump ground to the engine block.
that relay,when the yellow wire is ECU grounded ,closes the circuit between the black and the blue for the fuel pump ground.
yes some of the diagrams bite but its way way better than the 80's and 90's.
if the key on power yellow wire to the ECU fails or has low voltage,the ECM wont communicate.
same if the ECU ground path is bad.
Originally posted by rodbolt17 View Postok, so now we know the control side of the relay is working.
is the ground path on the relay black wire good?
can it maintain 12V on the y/r at key on?
can it maintain the ground path from the ECU yellow wire?
can it maintain the fuel pump ground path across the relay contacts to the fuel pump?
does the fuel pump yellow red wire maintain its 12V+?
lots of things happening all at once.
lose any of it and the pump quits.
remember that pump draws over 7 amps,way more than what the ECU transistors can typically take.
so the used a relay to operate the fuel pump ground path.
that distribution block is one of those big square black doohickys with wads of wires.
there is also one for various block grounds.
at key on the ign yellow wire wakes up the ECU which wakes up the main relay which powers up that distribution block and supplies 12V+ to any device with a yellow/red wire.
about the same time the ECU drops a dime and sends a ground signal to the fuel pump relay via that yellow wire to the relay.
this causes a current flow in the relay magnetic coil closing the relay contacts.
now that blue wire from the fuel pump is,or should be,connected to the relay black wire which is or should be connected to the block.
the ONLY function of a relay is to use a very low operating current to control a much higher current.
we would not need trim relays if the operator did not mind wiring the helm with 6GA wire and switchs the size of a battery switch.
with a relay for the trim we can control a 30+amp draw with a control amperage of less that 1.
on the ECU it goes back to heat,7+ amps is a lot of heat.
Originally posted by rodbolt17 View Postis the ground path on the relay black wire good?
on the ECU it goes back to heat,7+ amps is a lot of heat.Last edited by Hunter#1; 05-03-2015, 02:39 PM.
easiest way?
use the volt setting,use paper clips to back probe the connections at the pump.
place the red lead on the blue and the black lead on the engine block.
turn the key on.
you should see 0V for 3-5 seconds(or very close to it) then switching
to 12V.
what you are doing is measureing the voltage DROP along a wire.
if every connection between the pump blue wire connector and the engine block was perfect you would see 0V when the pump was running,if you see 12V that means the voltage path is to the pump,through the pump but NOT to the engine block.
that is the SAME path the current has to take.
remember Voltage DOES NOT flow its ssimply a measure of electrical pressure.
CURRENT flows and is measured in amps, current is what does the work.
think of that blue wire circuit to ground,electrons don't see connectors and relays,as far as the electrons are concerned its simply a piece of wire.
so from the pump blue wire to the engine block with the relay energized you should see less than .5V..
now open the relay or introduce a bad ground connection and you will see the voltage climb ,depending on how bad the connection is it will climb to supply voltage.
resistance checks are ok, I prefer watching a voltage drop when the device is operating,or supposed to.
think of it this way, them electrons are caddilacking down the old wire heading from a source(bar maybe) to home.
if the path is clear there is no resistance and no pressure from the source.
now them trons see a bad relay connector or the bridge is out.
they either have to slow down,pressure from the source is now pushing, or they stop.
if stopped full pressure is pushing but they cannot move.
turn the key on.
to 12V.
Question - If I repeat the test in the morning when the problem has been typically presenting that Boscoe had me do earlier (with key on and relay removed check r/y wire for 12V and yellow for ground continuity) would that tell me if the ECU was bad? Or not getting 12V on the yellow lead?
Â
