2005 F200, runs up to speed fine, easing off the throttle is fine but if I rev it up and drop the throttle fast the engine dies. Particularly when you're docking and needs to get the throttle up quickly and briefly to pull away from banging onto the dock. It cranks right back up. What could be causing this?
New to me boat and motor and only took it out once.
I'm able to duplicate this on muffs as well. It also seems the screw on the front the throttle friction adjust knob seems to do something. I can tighten it then it gets loose again.
