Any red flags with my YDS ? 2002 F115
  • Any red flags with my YDS ? 2002 F115
    21 hours ago
    * 2002 F115 220 hours
    Hey all, I have been trouble shooting an intermittent power loss up top and an intermittent stumbling at ideal issue for a few months now. I will link to my original post where I go into great detail about the issue and outline all of the steps I took to remedy the issue. Unfortunately , I spent much of the the season trouble shooting with no luck. Now, spring is approaching and I really want to have a reliable boat before summer. I am suspicious that my intake pressures are too high. I have done a compression test and everything comes back great. I am waiting on a leak down tester in the mail. The motor only has 220 hours so I would be surprised if a valve is leaking... but I figured a leak down test would be a good place to start.
    Question: Dose anyone have numbers that I can compare my YDS too? Or can anyone look over my read out and ID red flags/areas of interests.
    Thank you in advance! Love this community !
    Diagnosis
    13 Pulser coil Normal
    15 Water temp sensor Normal
    17 Knock sensor Normal
    18 Throttle position sensor Normal
    19 Battery voltage Normal
    23 Intake temp sensor Normal
    28 Shift position switch Normal
    29 Intake press sensor Normal
    37 Intake air passage Normal
    44 Engine stop lanyard switch Off
    49 Over cooling Normal
    Diagnosis Record
    Total hours of operation 209
    Code Item Occurred
    28 Shift position switch 10.4
    13 Pulser coil 87.9
    15 Water temp sensor 97.3
    23 Intake temp sensor 116.6
    18 Throttle position sensor 208.2
    Engine Monitor
    Monitor Item Result
    Engine speed 0
    Intake pressure 101.88
    Intake pressure 30.16
    Atmospheric pressure 1018.8
    Atmospheric pressure 30.2
    Ignition timing -
    Battery voltage (12-16) 12.7
    TPS voltage (0.5-4.5) 0.762
    Throttle valve opening (0-90) 1.6
    ISC valve opening 65
    Fuel injection duration 0
    Water temperature (below 90) 25.9
    Water temperature (below 194) 78.5
    Intake temperature (below 70) 13.7
    Intake temperature (below 158) 56.7
    Engine stop lanyard switch OFF
    Shift position switch ON
    Oil press switch ON
    Dual engine system switch OFF
    Data Logger[Engine operating hours according to engine speed]
    Engine speed Time[h]
    - 1000 r/min 54.4
    1000 - 2000 r/min 54.4
    2000 - 3000 r/min 22.2
    3000 - 4000 r/min 9.9
    4000 - 5000 r/min 32.1
    5000 - 6000 r/min 14.7
    6000 - 7000 r/min 1.5
    Engine hours 209
    Data Logger[Data comparison graph]
    Engine speed[r/min] Battery voltage (12-16)[V] TPS voltage (0.5-4.5)[V] Water temperature (below 90)[°C] Intake pressure[kPa]
    950 14.65 0.76 48.7 52.8
    1350 14.58 0.84 48.7 60.7
    1550 14.58 0.86 48 66.1
    1550 14.43 0.86 48 66.1
    1550 14.94 0.86 48.7 65.6
    1550 14.43 0.86 48.7 66.6
    1550 14.14 0.86 48.7 65.6
    1700 14.58 0.9 48.7 68.1
    1000 14.43 0.78 49.3 52.3
    1100 14.5 0.78 49.3 46.9
    1100 14.79 0.76 48.7 45.9
    1050 14.28 0.78 48.7 47.9
    1100 13.99 0.76 22 46.4
    Hi,this is just my humble diagnosis.....your diagnosis record indicated error recently at 208.2 hrs.Your TPS voltage/throttle valve opening is out of specs...u may need to link & sync to specs.
